stupid springs.....
Old 01-05-2003 | 08:58 PM
oc_civic's Avatar
oc_civic
mcc racing
you have any kind of adjustable shocks or anything.. i KNOW you posted that info in the other thread but im too lazy to look.. lol
Old 01-05-2003 | 09:02 PM
HondaCar's Avatar
HondaCar
Honda Driver
Public Service Announcement (Not directed at anyone in particular)
E before I, not after...
:thumbup:
Old 01-06-2003 | 10:42 AM
skubb's Avatar
skubb
not that TLC sh!t either
whenever you lift up say the right rear to put on the spring, the left will compress more. when you let the right side down, it will stay higher than the left for a while.
the springs are brand new right? theyre made to withstand alot of pressure, they just gotta get used to all the pressure for a while before they settle and stay evenly.
Old 01-08-2003 | 10:00 PM
flappy188's Avatar
flappy188
O.G. SON!
was ur ebrake on??????????
Old 01-08-2003 | 10:32 PM
smudge's Avatar
smudge
How are your bushings?Damn, sorry 'bout all the bad luck .
Old 01-09-2003 | 12:24 AM
toadolson's Avatar
toadolson
The One And Only!!!
Just had my new springs and struts on. Had them in for a month now. Did a finger test. Front was just fine. Even. Rear driver side had a 1.5 finger gap. Pass side had a 3 finger gap. had them swap out the two side to see if the springs or struts were bad. Same problem. Ask if the car was ever wrecked. Front drivers side got a little damage from a freak wreck. With the uni-body construstion, something small can tweak the frame. Told me to take it to a frame shop, get it measured. Should be able to get a bry bar and pull the frame back staight. It worked for me.
Old 01-09-2003 | 05:13 AM
crucial Si's Avatar
crucial Si
Banned
so your even all around after you got the frame pulled?
Old 01-09-2003 | 09:46 PM
toadolson's Avatar
toadolson
The One And Only!!!
No frame. Uni-body construstion. Lazer guided frame shop should get you close. Will take a little time. Suspension mounts straight to the body panels. My civic does not have a rigid frame to mount on.
Old 01-10-2003 | 11:29 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Is the spring seated correctly on the shocks? Sometimes if you go over a big bump or pothole, it might shift the way the spring is seated. Jack it up and check it real quick.
