GSR VS CTR or ITR
i dont see how the b18c5 is over priced?
ive seen it for 4200$ while the going rate for b18c1's is around 3000-3300...
so better gearing, LSD, Friction coated internals, higher red line, higher compression, 20 hp more, blah blah blah isnt worth the 1300 to 1000$ ? i dont get it oh well
Originally posted by ChulpaMiVerga
So you think a b20 vtec then? That's like a honda crv motor isn't it how much hp does the b20 vtec motor put out? And how much do they go for usually?
Originally posted by MrFatBooty
Read my post. I said "if you're going to be building the thing." If you're going to be buying aftermarket cams, an LSD, etc etc etc, there's no real reason to buy those parts in not as good versions already installed in the R motor.
