FMU and INLINE FUEL PUMP questions???
Old 11-22-2002 | 11:02 PM
turbotangelo's Avatar
turbotangelo
Default FMU and INLINE FUEL PUMP questions???
My friend just bought a vortech supercharger kit for a cobra. I was wondering if the T-REX inline fuel pump and Vortech FMU will work on my 94 honda civic. He has offered to sell them to me for $75 and if it will work it'll be a deal. Im about to install my turbo and im needing the extra fuel i also have 370cc injectors to go along with it. Also is there anything else i need fuel wise to help out other than standalone. Just needing to know if it should work like the ones that vortech makes for the civic. Thanks for the info Cody.
Old 11-22-2002 | 11:57 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You're not going to be able to idle 370s if you're using your stock ECM, which I assume you are, since you want to run an FMU setup. What ratio is the FMU? If it's 12:1, you can run it with your stock injectors. Inline pumps are pretty much universal, so as long as you can plumb it, you can run it.
