Ls/vtec
Old 12-16-2002 | 06:50 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Originally posted by genyosai
I see. The reason I asked is because I have two blocks that I just got back from Import Builders. One is a GSR build, so it doesn't matter, the other is an LS build. I noticed on the LS block that the orifice hole is plugged there with an 1/8npt plug. Just wondering if this would suffice or would you have to plug the head as well.
Thanks,
I would plug the orifice in the head. You don't want to risk it beign left open, since it could have an effect on your VTEC oil pressure. If the pressure in the VTEC plumbing isn't high enough, VTEC won't work.
Old 12-16-2002 | 06:55 PM
genyosai's Avatar
genyosai
I understand. I'm all to familiar with loosing VTEC oil pressure. Had a 97 Prelude that was good for it. That car used 1qt oil every 3000miles. I drove it hard, but no harder than any other car I've had. Anyway, I always knew when I'd corner hard and VTEC shut out.
Thanks,
