I hate this bring this up but... intakes.
Old 11-11-2002 | 04:22 AM
SeeCamGo's Avatar
SeeCamGo
LIGHTS Army Soldier
Well I think what I'm going to do is cut the pipe so where I could stick on the filter, and it would be a short ram, in the rainy season. And when not, I will stick on the bypass valve, and the rest of the pipe, for cold air again. That should do it.
Old 11-11-2002 | 04:23 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by crucial Si
:chuckles: you know from experience h:
yes I do.
I made $1700 from it though.
Old 11-11-2002 | 05:37 AM
crucial Si's Avatar
crucial Si
Banned
Originally posted by westcoaststyle
yes I do.
i have an idea, but i need my motor running right now, if not i would have a b16 done in a couple weeks.
Old 11-11-2002 | 07:40 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Originally posted by K i o n
methinks that article was a tad misleading, the filter was aimed STRAIGHT down in a fishtank that wasn't moving, while most CAI filters will be somewhat angled, and water will usually be splashing about when you drive through it... what were to happen if tons of water were to splash up without completely submerging it (thus bypassing the bypass valve, since it only closes when the filter's completely in)
a lot of people agreed with you and all, but i dont see how, your comments make _no_ sense.
Old 11-11-2002 | 07:51 AM
westcoaststyle
It is a little confusing, but it makes sense to me.
Old 11-11-2002 | 07:57 AM
Fujiwara Takumi
It's my first day.
well, put a straw half submerged in a cup of water and suck as hard as possible without fully submergine the straw, chances are you will never get any fluid.
or heres a godo example of that breather valve. take a straw and poke holes all over half way up, submerge it completely at the bottom and suck hard. even the milwaukee brewers dont suck hard enough to get fluid up that straw.
Old 11-11-2002 | 08:07 AM
westcoaststyle
:rofl:
Good example.
Old 11-11-2002 | 08:32 AM
SeeCamGo's Avatar
SeeCamGo
LIGHTS Army Soldier
How wold you guys prop it up if I were to cut it into a short ram in between the sticker and the bend in the pipe?
Because me cutting it between the sticker and the curve would remove the parts thats holding it up... How are usual Short rams braced? And how would I go about doing this?
Old 11-11-2002 | 08:33 AM
westcoaststyle
:thumbup:
Old 11-11-2002 | 08:38 AM
Fujiwara Takumi
It's my first day.
i got this bent little metal bit that i ended up bolting under the a arm bolt and slipping under the rubber sleeve in the middle:
you cant see the mount in this picture, but i think you get an idea of what i mean.
if you do cut the tube make sure to sand the lips down a bit so you dont cut the dickens out of your hand next time you take it apart.
*edit* actually you can kinda see it if you look close, its on the front side of the strut tower.
