I hate this bring this up but... intakes.
Old 11-10-2002 | 06:47 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Default Re: Re: I hate this bring this up but... intakes.
Originally posted by tokyoracer
dude... there is a way to do it without having to spend more money. first of all, don't get a bypass valve.. cuz that is a waste of money where other areas will be better spent. what u can do is cut the piping and connect it with the rubber tubes that they use for the turbo piping. this way, if you want a short ram.. just remove it and pop on the filter... and if you want it long.. just connect it. it will save you a lot more $$$ instead of buying another short ram.
yes, mine came that way, use it as an idea of where to hacksaw your pipe:
Old 11-10-2002 | 06:51 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I think that's an awesome idea!
You'd have to cut it anyway to put the bypass on it. If you cut it and just put your filter on there, you'd be running a short ram. If you just get another piece like where it connects to the tb you could make it a cold air again. That way when it rains you could make it short and when it's dry, cold air!
I love the idea! Good call! :thumbup:
Old 11-10-2002 | 08:25 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default Re: Re: Re: I hate this bring this up but... intakes.
ur welcome... but i think when u do cut it... make sure u cut off at least 1/4 in. off the tube... so this way when u reconnect it.. the piping doesn't rub up against each other.
Old 11-10-2002 | 08:29 AM
br0nx finest's Avatar
br0nx finest
I drive a cb7, y0.
i agree, but what is the reason that the bypass valve would create a loss of power, and isnt it guaranteed not to ingest water, didnt you guys read sport compact car, they did a complete water ingestion and not a drop went past the bypass valve
Old 11-10-2002 | 08:51 AM
The Bum's Avatar
The Bum
Black people go wooooo
I read that article also, and when someone has the balls to put their acura NSX's cold air intake into a fish tank full of water, I'm going to trust them. With the bypass I do not see any way that enough water could get into your engine to damage it.
Also, as LoOkN4 said, how would it create a loss of power? I don't see any way that it could.
But, to save money I agree with the other guys that said chop off 1/4 inch of the piping and switch from CAI to shortram whenever necessary.
Old 11-10-2002 | 08:57 AM
antarius's Avatar
antarius
Large Member
If people are talking about making the tube not "smooth" anymore and causing turbulance, and THAT causing a loss of power....
Perhaps those people should look at the new AEM intake that purposely gets smaller to induce some turbulance.
Just throw the damn bypass valve on, you wont notice loss of power and you wont have to worry.
Me... I have a short ram.
Old 11-10-2002 | 09:59 AM
crucial Si's Avatar
crucial Si
Banned
that article was complete bullshiit. they extended the intake w/ a clear tube...blah blah, it doesnt convice me. anyhow, you loose power back to stock, so why waste another $50 to have something pretty in under the hood that does absolutly nothing?
Old 11-10-2002 | 05:02 PM
K i o n's Avatar
K i o n
TrackDemon
methinks that article was a tad misleading, the filter was aimed STRAIGHT down in a fishtank that wasn't moving, while most CAI filters will be somewhat angled, and water will usually be splashing about when you drive through it... what were to happen if tons of water were to splash up without completely submerging it (thus bypassing the bypass valve, since it only closes when the filter's completely in)
Old 11-10-2002 | 06:40 PM
westcoaststyle
:werd:
Old 11-10-2002 | 06:48 PM
crucial Si's Avatar
crucial Si
Banned
:werd:
:chuckles: you know from experience h:
