aem bypass valve
Honorary Moderator Alumni
The bypass valve works using little flaps.
The flaps are meant to open with suction through the tubing gets too high causing the flaps in the valve to open.
The valve installs along the upper portion of the inlet pipe on the same axis as the throttle body centerline. Should a drop in pressure occur within the pipe due to filter submersion, the valve shuts down induction at the filter and routes incoming air through its external orifices, eliminating any chance of water ingestion.
Autocross Help Page
Autocross Help Page
