1999 civic grille
Old 03-08-2008 | 07:30 PM
thecivictuner's Avatar
thecivictuner
Default 1999 civic grille
ok i got a 99 civic ex the other day and i wanna remove the inner part of the grill so i can either leave it open or put some mesh in. how do i take that out?
Old 03-08-2008 | 11:57 PM
Line7's Avatar
Line7
Platinum Member
you will have to cut it out.
Old 03-09-2008 | 02:45 PM
egibbs1's Avatar
egibbs1
cut it out or use a razor blade and a torch for a smoother cut.. have the same car and did that project the other week... doesn't take long at all
Old 03-09-2008 | 04:07 PM
thecivictuner
alright thanks, i assume i would do the same to cut out the blades in the front bumper as well? also would that effect engine temp, because isnt the purpose of a grille not only to be looks but also to direct the air into the radiator in a certain way and therefor keeping the engine cooler?
Old 03-09-2008 | 07:42 PM
Line7's Avatar
Line7
Platinum Member
If you want a mesh grille, you could just put it over your existing grille. No need to cut it really.
Old 03-31-2008 | 05:34 AM
ozzie31220's Avatar
ozzie31220
Buy a new one, pretty much all cost and look the same. You can buy them with or without the mesh.
