98 JDM b18c in a 95 Cx Hatch?
Old 10-21-2002 | 02:20 PM
flappy188's Avatar
flappy188
O.G. SON!
Default 98 JDM b18c in a 95 Cx Hatch?
i wanna do this swap soon! and i was wandering what ill have to do in order to get the car running properly! i heard the the harness will be an issue, what will need to be done to get the harness to work?? i also heard the my car being an obd1 and the motor being an obd2 will be an issue also, so basically iam wondering everything ill have to do after the engine is in the car???? any problems that im gonna run into...oh yea i dont have emissions either!!!! Please help me out or give links,,
Remember its a jdm motor!!!!:thumbup:
Old 10-21-2002 | 02:27 PM
crucial Si's Avatar
crucial Si
Banned
the only thing that makes the car obd2 are the injectors and distributor...just get them off of a obd1 and youll be good...someone correct me if im wrong.
Old 10-21-2002 | 02:57 PM
flappy188's Avatar
flappy188
O.G. SON!
Default correct him if hes wrong
i also heard that the japenese like to cut hoses and wires insted of just unplugging or pulling them off???
also what other kinds of problems am i gonna run in to with a jdm swap!!!! obd1-2 c'mon i know u guys know!!!
ttt
Old 10-22-2002 | 02:08 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
Doh! It's been so long since I've done this swap! If I remember correctly, you'll need an OBDII GS-R harness. Plug it all in. It should plug into your chassis harness. After that, get the OBDI P72. You'll have to rearrange some pins so be sure to get the OBDI and II P72 pinouts. Also, don't forget about exhaust extension. Beings you don't have to smog, just make a really LONG test pipe. And yes, they do like to cut them suckers out of there. Takes less time. Also, be sure to flush out that motor. I've heard they don't change their oil over there. I remember we cracked open a jdm B16 oil pan when we first got the motor and it was NASTY! Oil stained and sludge all over the place.
Old 10-22-2002 | 07:23 AM
qtiger's Avatar
qtiger
You'll end up with about 5 sensors you won't be using.
Old 10-22-2002 | 08:25 AM
flappy188's Avatar
flappy188
O.G. SON!
Default that dosent sound too good
can that be a good or a bad thing? i mean those sensors are there for a reason!
Old 10-22-2002 | 09:23 AM
qtiger's Avatar
qtiger
Default Re: that dosent sound too good
OBD1 engines managed without them. Honda made their systems more sophisticated with OBD2, adding a few sensors that let the ECU keep a better eye on the engine. (CKF, 2nd O2, etc.)
Nothing too serious.
