please help meut wt sway bars and tie bars
Old 10-13-2002 | 09:46 PM
RHYMESAYER's Avatar
RHYMESAYER
Default please help meut wt sway bars and tie bars
can you guys please tell me what the functions are of tie bars and sway bars, i woul appreciate it, also can you show me some pics of th eboth of them. And also if you know of any sites that will sho eme drections on how to install them jut incase maybe i decide to get them in th future if i feel they are needed. Thanks alot
Old 10-14-2002 | 04:04 PM
str8edgexx's Avatar
str8edgexx
Default Re: please help meut wt sway bars and tie bars
ok, basically, a tie bar links both sides of your suspension and provides you with rigidity. A sway bar helps to transfer the momentum of your car, and dramatically limits your body lean (going around turns). Generally, the thicker a swaybar, the better it works (although there are drawbacks of having very thick ones) Depending on what type of civic you have, there is a chance it comes stock with a front sway bar. I'm not sure about 5th gens, but I know all 6th gen Lxs , Exs, and Sis have a front sway (22mm). Sis came with a rear swaybar as well (some say 13mm but Honda says 15mm). I personally put an '99 Si rear swaybar on my Lx to compliment my stock front one, and have a Neuspeed tiebar on the back as well.
Heres a pic...hope it helps. If you have questions, let me know.
Old 10-14-2002 | 08:32 PM
RHYMESAYER's Avatar
RHYMESAYER
thanks alot, do you have to drill another hole to install a sway bar??? i have a 98 hatch
Old 10-14-2002 | 08:35 PM
Nelson's Avatar
Nelson
Administrator
Default Re: Re: please help meut wt sway bars and tie bars
:werd: :thumbup:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 10-14-2002 | 08:56 PM
RHYMESAYER's Avatar
RHYMESAYER
is the sway bar the thing that says neuspeed??? and do tie bars connect to sway bars?
Old 10-14-2002 | 09:35 PM
RHYMESAYER's Avatar
RHYMESAYER
do you have to have tie bars and sway bars on at the same time, or can you just have one or the other??
Old 10-15-2002 | 03:28 AM
str8edgexx's Avatar
str8edgexx
I'm not sure about hatches, but on my '98 Sedan, I didn't have to drill extra holes. The holes were already there in my lower control arm. Its easy to tell. Just go out to your car, and look down at your back wheels...if you see a hole in your control arm, then you don't have to drill (if you look in my picture, you'll see a bolt in the extreme left hand side of the picture...this is where the hole would be if you had it).
The tiebar is the piece that says Neuspeed. The tie bar connects to the pivot joints that hold your lower control arms to the body of the car. It basically helps connect each side of your suspension together, and provides you with rigidity. Tie bars don't connect sway bars...they are two seperate entities.
You don't have to put tie bars and sway bars on at the same time. You can have one or the other, or both. Since they are not connected, you are able to put them on at different times. I put mine on together because I figured if I was working down there, I might as well kill two birds with one stone. Also, by adding both pieces at one time, you'll notice a more dramatic effect in handling than if you added them seperately.
Old 10-15-2002 | 03:31 AM
str8edgexx's Avatar
str8edgexx
oh, and also....since you have a hatch, its either a Dx or a Cx, and to the best of my knowledge, they did not come with front sway bars. You would have to get one of them too. You could just get one from an Ex or an Si (again, the holes and everything are probably there), or go with an aftermarket one.
Old 10-15-2002 | 05:10 AM
Brad's Avatar
Brad
wooo nascar!
i had to drill to install my suspension techniques rear sway.. the neuspeed rear lower tie just bolts on
