radiator leak
Old 07-21-2007 | 12:35 PM
mini-me civic's Avatar
mini-me civic
Default radiator leak
i jus installed a used high flow aluminum radiator but, problem is it has a small leak near the filler neck where the cap goes. There is a little hole and it leaks very little. I was wondering if there is any way i can repair the leak and what can I use. I dont wanna use the stop leak radiator crap that you jus add into the coolant cause i just dont trust that crap. so yeah jb weld wont handle the heat right??
Old 07-21-2007 | 12:38 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Can you return it? Sounds like something that's just going to continue to mess up the pressure and cause continuous overheating.
Old 07-21-2007 | 12:49 PM
A-series's Avatar
A-series
v-card member alpha
I know they use solder to hold parts of rads together(and ensure good contact), not sure if it's lead like typical solder or tin or something :hsdunno: but I would think it would be safe to solder it. :thumbup:
I've very little soldering experience but that wouldn't create enough heat to cause a problem, just be sure to get good coverage (maybe more than one "coat") and the type of solder may matter as far as temp. and corrosion-resistance.
Old 07-21-2007 | 07:09 PM
mini-me civic
yeah i heard about the solder thing. imma try to go to a radiator shop and see if they can some how fix the hole with an aluminum welder or somethin.
Old 07-24-2007 | 06:47 PM
Jackie's Avatar
Jackie
As far as I know, a solder would be the only thing to fix that. If you don’t have the tools and materials, it would be more practical to bring it to a shop. Those kinds of problem are the reason why I prefer taking a new honda del sol radiator than a used one. Used are cheap, but it would still make you spend much on repairs if it’s not in good condition, unless you were able to get them for free.
Old 07-24-2007 | 06:53 PM
foot's Avatar
foot
At this point you have to decide if it's worth having someone fix it or if you should return it for another one. I would find a radiator shop. Or someone with a tig welder.
Old 07-26-2007 | 04:09 PM
audiokong's Avatar
audiokong
braize it or return it lol
