b18a1 into 94 civic EX soupe
this is my first swap and i was wondering if i could get some help...the swap somes with:
ys1 ls cable tranny
shift linkage
pr4 obd-1 engine harness
obd-1 pr4 dizzy
obd-1 pr4 ecu
Fidanza 8lbs Flywheel installed
exedy stage 1 clutch installed
recent throwout bearing
new rear crank seAL
new timing belt 10,000 miles ago
both axles need boots
Front hub assemblys
and the stock mounts out of the 92 integra
what else will i need for this swap? and what will i have to do about the wiring harness? ami going to have to hack it all up or what? the car is a 94 5 speed civic EX w/ d16z6. any help would be appericiated. thanks
ys1 ls cable tranny
shift linkage
obd-1 pr4 dizzy
obd-1 pr4 ecu
new rear crank seAL
Front hub assemblys
don't even need the harness, just transfer the one form your civic over to the integra motor. No cutting needed all sensors will plug right into the harness. You will need motor mounts from a 94+ integra, as the 92 mounts won't work. Also the front hubs on the 94 are perfectly fine you don't need to swap them out just grab a set of 94+ teggy axles and you are good to go. Also you will either need to find yourself a hydro tranny or get the HASport cable to hydro conversion kit.
