engine swap help b18a1 into a 95 civic dx
Old 07-01-2007 | 10:06 AM
hi10s's Avatar
hi10s
Default engine swap help b18a1 into a 95 civic dx
anyone pls..... is b18a1 fit right into 95 civic dx?
Old 07-04-2007 | 06:05 AM
Trance303's Avatar
Trance303
It should , you will need the engine,trans ,axles, ecu, shift linkage, engine harness, all from the acura. you will also want to cang the motor mounts to soilid urithain, (on my car the rubber ones kept ripping).. Any question feel fre to ask.
Old 07-04-2007 | 07:22 AM
Civic2Scooby's Avatar
Civic2Scooby
and if you want to actually drop it in without having to hack up your harness.
b18b intake manifold
b18b dizzy
b18b exhaust manifold
94+ integra rear trans mount bracket
b18b motor mounts
HASport cable to hyrdro conversion kit if you use the b18a trans
94+ teg axles
94+ teg Vehicle Speed Sensor
94+ teg throttle cable
94+ teg b18b ECU
Old 07-08-2007 | 05:23 PM
hi10s's Avatar
hi10s
thanks for all the info guys......
