tein springs instead or eibach prokit?
Old 03-25-2007 | 06:06 PM
bmallen11's Avatar
bmallen11
iLURK
https://www.honda-acura.net/forums/s...d.php?t=246127
That should help
Old 03-25-2007 | 06:15 PM
Originally Posted by dspencer24
will 17's with a 40 series tire rub with the tein s springs
if your having ride comfort issues ...
i would venture a guess that the 17's your rolling on are causing part of those issues...
17's are just too big for a civic
Old 03-25-2007 | 07:51 PM
dspencer24's Avatar
dspencer24
b18c ftw
yeah i know your right, but i like the looks of them and i havent found any rims that i like in 15 or 16s
Old 03-26-2007 | 07:50 AM
Wharbone's Avatar
Wharbone
aahhhh makes sense do you know where to get ground control coilovers that fit them, or would tokicos work just as good.. Or should i just stay with kyb agx's
I use tokico's w/ h&r springs. I like them. They are 5 way adjustable so you can get them pretty cushy if that's how you want it to be.
I have never used kyb agx's or koni's, but from what I have heard agx<tokico<koni.
You can order them directly from Ground Control if you want. Usually coilovers will give a harsher ride, so if you are going for ride comfort, you may want to also get custom spring rates as well.
Old 03-26-2007 | 05:51 PM
dspencer24's Avatar
dspencer24
b18c ftw
has anybody used the two different struts? kyb or the koni's i want to get adjustable springs but is it worth it to change my struts if I already have agx's
Old 03-26-2007 | 06:00 PM
Wharbone's Avatar
Wharbone
Personally, I would keep them. You can always change them later.
As long as you are riding on 17's and performance suspension parts, the ride isn't going to be what you want.
I'd just try some softer spring rates and see if that satisfies you.
Old 03-26-2007 | 06:07 PM
dspencer24's Avatar
dspencer24
b18c ftw
yeah i wanted to try the tein s but, i dont want to rub and dont know how low that will put my civic.. i like the 17s for now. the eibach springs i have arent that agressive its the prokit and the back sits low there is barly anyroom for a finger and the front is higherwith atleast a couple
Old 03-26-2007 | 06:11 PM
dspencer24's Avatar
dspencer24
b18c ftw
i wondder if they are backwards i just looked at there website and its said 1.5 in the front and 1.3 in the back lol not on my car it isnt
Old 03-28-2007 | 07:20 AM
dspencer24's Avatar
dspencer24
b18c ftw
http://cgi.ebay.com/ebaymotors/TOKIC...97500242QQrdZ1
is this a good price i would match those with these below
http://cgi.ebay.com/ebaymotors/GROUN...spagenameZWDVW
or these ones
http://www.cardomain.com/item/NRGSCO310?vq_id=none
or spend 300 more for a koni set up with a ground control coilovers for them
Old 03-28-2007 | 09:53 AM
dspencer24's Avatar
dspencer24
b18c ftw
does anybody have the tokico illuminas with ground control coilovers
