Wiring b18c1 into EG
Old 10-16-2006 | 12:59 AM
95LSv's Avatar
95LSv
Banded
Default Wiring b18c1 into EG
I just swapped my 95 b18c1 into my 93 eg hatchn:yay: , and heres the tough part... i guess. I need some help with the wiring... Can I just use a GSR harness? (the 3 main plugs connect but the eg car harness is missing a little plug that the gsr one has ). So if anyone could help me out I would really apreciate this. Thanx.
Old 10-16-2006 | 04:32 AM
94Hdelsol's Avatar
94Hdelsol
Default this may help.
Articles
5G Civic/3G Integra Engine Swap Matrix
Target CarSource EngineRemarks92-95 Civic
92-95 Del Sol
94-95 Integra
B18C1
B16A2
B18B1
  • Direct bolt-in swap
B17A
  • Requires hydraulic transmission or HASport cable clutch conversion Kit
B18C5 (Type-R)
  • Requires OBD-2 conversion wiring
H22A (Prelude)
  • Requires H22A mount kit from HASport or Place Racing
  • Requires wiring harness modification
96-97 Del Sol
96-00 IntegraB18C1 (96+)
B18C5 (Type-R)
  • Bolt-in swap
H22A (Prelude)
5G Wiring Information
B16A2 in EG Civic
There are 6 lines to check on.
Engine SideECU SideDesciptionWire ColorPin/ConnectionVTEC SolenoidYellow/GreenA4VTEC Oil Pressure SensorBlue (passenger side harness)D6VTEC GroundBlackchassis groundKnock SensorRed/BlueD3Evap Purge PowerYellow/Black12V power (hot in ON or START)Evap Purge SolenoidRedA20
B18C1 in EG Civic
Check on the following 7 lines to see if everything is there and if they are hooked up right.
Engine SideECU SideDesciptionWire ColorPin/ConnectionVTEC SolenoidYellow/GreenA4VTEC Oil Pressure SensorBlue (passenger side harness)D6VTEC GroundBlackchassis groundKnock SensorRed/BlueD3Evap Purge PowerYellow/Black12V power (hot in ON or START)Evap Purge SolenoidRedA20Secondary Intake SolenoidPink/BlueA17
ECU Pinouts
EG series Civic (5G, 92-95) and DC series Integra (3G, 94+)
Old 10-16-2006 | 09:45 AM
95LSv's Avatar
95LSv
Banded
Wow very helpful, thanx a lot
Old 10-16-2006 | 10:19 AM
94Hdelsol's Avatar
94Hdelsol
No problem
Old 10-16-2006 | 10:48 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
VTEC, Knock Sensor, IAB. Just add 3 wires and pin them to the ECU :thumbup:
Old 10-16-2006 | 03:20 PM
95LSv's Avatar
95LSv
Banded
So I have to use my civic oem harness? (that sux, because i thing its all spliced up from when they did the ITR swap when past owner had it, anyhow they did a hackjob). What would it take for me to use a obd 1 GSR harness? Is that possible? And what about all those extra sensors and the gsr intake mani?
Old 10-16-2006 | 03:27 PM
95LSv's Avatar
95LSv
Banded
Ok, so I have the 93 canadian made civic, where the gsr harness matches the civic car harness perfectly except one of the 4 gsr plugs has nothing to plug into. It is the smallest plug. So could I just use a gsr harness. Can anyone help me find what that one plug is?
Old 10-16-2006 | 03:29 PM
asiandoood's Avatar
asiandoood
because you are 93+ on the chassis, you'll need to wire up VTEC.
On the GSR, you'll need to add a wire for the IAB (intake manifold) and Knock Sensor. That should be it. Everything else is plug and play.
Old 10-16-2006 | 03:30 PM
asiandoood's Avatar
asiandoood
im assuming one that just hangs on the passenger side? You dont need that as mine is tucked away.
Old 10-16-2006 | 03:39 PM
95LSv's Avatar
95LSv
Banded
Wait, if I use the gsr engine harness, I would have to add hte vtec wire to the plug on the eg car harness, right? And the other 2 sensors as well, I would have to add to the car harness, since the gsr engine harness already has everything needed for the motor. Correct me if I'm wrong.
