Help taking off window tint!
check the defrost lines if they are scraped up it's done! you need a new window the repair kits will fix small breaks less then 1" but the bad thing is tint doesn't stick well to the uneven paint used to fix the lines with so if your lines are messed up either do without the deforst then it's easy to scrape the tint off or replace the window then you don't have to worry about removeing tint.
