Replacing rear trailing arm bushings - doable?
I bought the mugen ones but never got them installed. I think the cheapest way to go about it without a press would be to remove the trailing arms yourself, bring em to a shop with a press with the bushings, and have them press in/out the out/new bushings.
BTW, I have the mugens for a 96-00 civic that I never installed. Wanna buy em?
me and my friend use a torch and heated the metal around the bushing and with a large flathead screwdriver, pry it away from the metal, and then it pop right out with a hammer. the process took 45min for both sides, came out clean, then we use a wire brush on a drill to clean it up more, lube it up and press the es ones in by hand.
I just did mine a few week ago. I replaced them with ES. The torch worked great. Although I had to use a box knife on some of it. I also used the wire brush drill trick. To get the bushing in I used a long bolt w/nuts and 2 pieces of metal 4" square. I drilled a hole through the middle and that was my press.
Hopefully you didn't knock out the outer shell of the OEM one and that's why the ES ones went in by hand. I had to use some circular plumbing parts and bolts to push mine in.
I've read about using a hammer to knock the old ones out and new ones in. I will be attempting this method since I now have 5 cars to do. I'm currently using the ES ones on my current driver, but they're starting to wear and I would like to get back to the rubber ones. The other 4 are just ripped OEM ones.
I would definetly have a plan B if you live in buffalo. Once those things get a even a little rusty it takes every bit of 20 ton press to get them out.
they supposedly "re-designed" the honda trailing arm bushings. Im curious what exactly they changed, do yours look any different than the new ones?
I don't have the new ones yet, I finally got a part number to show up on hondaautomotiveparts.com. Appearently the redesigned bushings number doesn't show any results. I have to call the local dealer and see what they say.
