Broken LCA bolt, bolt stuck in frame
Old 06-15-2006, 04:03 PM
aenima_20
aenima_20's Avatar
Default Broken LCA bolt, bolt stuck in frame
the remainder of the bolt is stuck in the nut that is welded on the frame
is it safe to chisel that nut off and put a regular washer and nut instead ?
heres a pic
http://img.photobucket.com/albums/10..._20/LCA004.jpg
Old 06-15-2006, 04:20 PM
eonsx311
today is not my birthday.
eonsx311's Avatar
thats all you can do, thats what i had to do on both sides.\
edit: and resize them pics brodius
Old 06-16-2006, 06:03 AM
aenima_20
aenima_20's Avatar
if I take an air chisel to the nut is there any chance that it would rip off a piece of the subframe with the nut ? or is it pretty solid metal ?
Old 06-16-2006, 07:18 AM
eonsx311
eonsx311's Avatar
yeah, that lca is just stamped steel, you really should grind or cut it rather than chissle it.
Old 06-16-2006, 07:19 AM
dpkelly
1999 Civic Driver
dpkelly's Avatar
I'd just drill out the bolt and leave that old nut on the subframe. Put the new nut on top of the old nut and call it a day. The old nut is like an extra thick washer.
Old 06-16-2006, 08:13 AM
bnuk
bnuk's Avatar
not a bad idea.. you could even drill and tap it one size larger if you wanted.
damn that is one rusty honda...
Old 06-16-2006, 08:29 AM
Kestrel
Push to shock!
Kestrel's Avatar
You could try a bolt extractor first too
Old 06-16-2006, 08:47 AM
Ctrld-Kaos
i need a wrench wench
Ctrld-Kaos's Avatar
that happened to me when i was puttin my lcas on.. i took a torch and heated up the side where the nut was, then i put vice grips on the side that broke. i then poured water on the hot side and twisted it out. make sure to heat the one side red hot or it wont work. the heat expands the bolt and when u pour water on it i shrinks to a size small enough to break it loose.
Old 06-16-2006, 08:59 AM
aenima_20
aenima_20's Avatar
thats a honda that's been through 13 eastern canadian winters
Old 06-16-2006, 09:02 AM
aenima_20
aenima_20's Avatar
there is no bolt left outside the nut, it broke flush to the subframe
I guess ill keep at it with the drill
