clock fuse
clock fuse
i checked the fuse box under the dash and under the hood and it doesnt say anything about the clock fuse.. i blew that fuse and i need to replace it but i dont know which one it is... there is no clock fuse.. can anyone tell me where and which fuse it is?
it will be your constant fuse im not sure which one that is called but your dome light should work eather. my sugestion is check every fuse by pulling them oout one by one to find it. it shouldn't take you more than a few mins. but im pretty sure you'll find it under the hood
Originally Posted by waaBAAH
did you install a radio? under the hood.....i think it is the same fuse that works on the radio. acc or radio...i forget
yes that radio/cig lighter is the fuse that connects to the radio. replace that one. does your radio work? did you install another radio or just take that old one out?
guessing gets you no where......but do look at all your fuses...pull out each one and check it.
