matching up headlight wires..
I bought a wiring harness off of passwordjdm and now I don't know which wires to match together. My stock harness has a red w/ white stripe, red w/ blue stripe, and black wire. My new harness has a red, white, and yellow wire. Any help?
Originally Posted by ReVenGe
i cant quite understand what your working on......what part of the headlight harness.... the plugs for the bulbs? or the plugs for the fuse box.....?
so you need to cut off the socket part plug thingy and then connect the harness to those?
if thats the case.. i believe the red/white is main, blue/white is alternate, and black is ground.... so i believe the main question would be is yellow or white ground for the harnes... and i would go with yellow
this is my guess so far:
red/white->red
red/blue->yellow
black->white
