My car keeps overheating HELP!!!!
Old 01-15-2006 | 07:54 AM
Hatch"R"Us's Avatar
Hatch"R"Us
Default My car keeps overheating HELP!!!!
my car has been over heating and i noticed that my fan does not turn on anymore.i checked the fuse that under the hood and it looks fine.what could it be.is there another fuse inside the car underneath the steering wheel.HELP!!!
Old 01-15-2006 | 07:56 AM
randomtask77's Avatar
randomtask77
Wanderer
There's a relay fan switch under the hood (next to the battery) so you might have to replace that. About 15 bucks at a parts store.
Old 01-15-2006 | 08:02 AM
Hatch"R"Us's Avatar
Hatch"R"Us
is that where the rest of the fuses are located at?will i find at autozone.
Old 01-15-2006 | 08:08 AM
randomtask77
Wanderer
It's the little black box thats next to your battery.
Just ask a person behind the counter. They'll get it for you.
Though you might want to tell them about your overheating problem. There are other factors as to why your fan isn't coming on.
Old 01-15-2006 | 08:11 AM
Hatch"R"Us's Avatar
Hatch"R"Us
what other issues could they be?
Old 01-15-2006 | 08:23 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Also could be a bubble in the coolant system. I'd let the car cool down, open the radiator cap and run the car for about 30 minutes to get air out of the system. Then refill with necessary coolant.
Autocross Help Page
Old 01-15-2006 | 02:29 PM
Civic2Scooby's Avatar
Civic2Scooby
I get ten bucks on your coolant temp switch....its a lil sensor that screws into your thermostat housing and tell the fan to turn on.....quick way to test if it is that or your fan is to unplug your fan and connect it directly to a 12v power source...if it turns on then it is 99% your fan switch.....that is the reason my fan stopped working and I have had to replace it on several friends cars as well.
Old 01-15-2006 | 04:16 PM
2000CivicSi's Avatar
2000CivicSi
Its that^^^ my car was doing the same thing. My uncle who is a mechanic walked me through the steps to get a bubble (well its called an airlock) out of the system and now its fine. My overheated all the time and the fans never came on even when the guage showed it was hot. After I did that and got the air bubble out my car has been fine since. Cheap fix. Only thing you may need to get is some more radiator fluid! Lates~
Old 01-15-2006 | 04:23 PM
Civic2Scooby
that still wouldnt be the reason why his fan isnt coming on. The fan is activated by a temp switch soooo an air bubble wouldnt stop it from working.
Old 01-15-2006 | 04:41 PM
MiloReaper87's Avatar
MiloReaper87
I have top agree with ^^^^^ the Sensor that activateds the fan is the Coolant Temp Sensor or water temp sensor (whatever u wanna call it?)
