Lower Motor Mount Brackets on DOHC Sol, need quick help ....
hey guys,
as most of you know i am getting ready to boost in the near future (3-4 months). i am making sure however that everything else is perfect under the hood before i actually do it. just recently i had an axle replaced and to my suprise, there were 2 motor mounts missing. I ain't shitting you. Anyways, i need to know exactly what they are called. I am not talking about the pillow motor mounts (ie: rear and sides), i am talking about the motor mount brackets that connect the block to the chassis and the tranny to the chassis UNDERNEATH, not on the sides like the pillow mount.
They look like L brackets kind of, but i just called Honda Parts and they had no idea what i was talking about. I have a b16 swapped in a del sol so i asked parts/service about the 94-95 DOHC VTEC Del Sol. They couldn't find the parts i was talking about so that has left me here.
Once again, the brackets connect at the bottom of the block and then connect to the chassis while the other one connects from the bottom of the tranny to the chassis. I need exact terminology guys so honda knows what i am talking about.
Thanks for the help
EDIT: O and if anyone has pics to post too that would be great. If no one still knows what i am talking about, i will put my car in the air tonight and take pics to post tomorrow. Just need help asap. thanks
Thanks for the help
Ok, lets see if i can describe even better since no one knows. The torque mounts found on www.jimfab.com The mounts stick into something. The two front lower mount brackets. Anybody know the technical term for these things ? I believe 1 is the AC bracket but don't know the other. since i don't have AC, will the ac bracket still work ?
search on hondaautomotiveparts.com and see if yours is supposed to have them. With the swap I don't know what should be there and what should not.
I just did my timing belt on my 92 and looked at mine, each side only has one bolt, the other ones I broke off trying to remove them, so there they sit with the rubber almost cracked all they through. No wonder the front end seems to stiffen up with the A/C on.
I know what you're talking about and I think I saw them available on Autohaus AZ's site also. I just can't remember what they're actually called, but it was under the motor mount section.
engine torque mounts
