!!! is this true !!!
Originally Posted by 3rdgenlxi
Ok, and what if you miss and get some of it on your paint? Can you say bye-bye clear coat !
Originally Posted by 93CivicLX209K
I saw a thread on another site about it...some claim about a 10% increase. It's supposed to make the gas vaporize better/easier. Only 3 or 4 ounces per 10 gallons recommended.
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
acetone will not increase your gas mileage...think about it...acetone is alcohol based and gasoline is not(synthetic fossil fuel). The acetone compound is not as dense as fuel (octane) thus acetone has a lower level of flammability. Adding acetone will give you misfire and may cause your car to stall if too much is added.
Push to shock!
That said, I fail to see how this will help your fuel economy. Your car burns approximately 95-99% of the hydrocarbons introduced into the cylinder through running as lean as possible and EGR. So, really the best you can do is about another 5% in fuel economy using the same thermodynamic cycle (ie without totally redesigning the engine). Also, there are issues with seal compatibility and acetone, which may or may not be an issue since the amount of acetone is so small.
