Front End Shimmy
thanks so much man lol i looked up the part its only 37 dollars but im gonna have it checked out first before i go buying anything.... hotmixer good luck with your car i hope his info helped you out too:thumbup:
To check your upper ball joint, grab the steering knuckle above the tire and pull back in forth in all directions. If it makes a sound, you definitely need a new one. I had clunking sounds too but are gone with a newer upper ball joint. It's easier to steer too now.
Originally Posted by syclone
all the posts above are correct possibilities.. well.. except the alignment one..
It may not be your main problem, but don't discount it.
wow.. you're just all kinds of messed up..
rip in ball joint boots will cause the clunking.. the shimmy will depend on which joint boot is ripped. lastly, clicking noises are normally associated with cv joints going bad.
CV joints will usually make most all of their noise when turning. That's the only time the balls in them are moving and could make noise. When the car is rolling in a striaght line, they barely have any motion. As with the ball joint boots, A ripped CV boot doesn't cause the clunking, but does need to be addressed.
Anytime you hear clunking noises, find it and fix it so you don't kill people.
