SRS light blinks when pulling CEL codes
When I jump the little connections to check my CEL code, instead of the CEL light blinking, the SRS light blinks non-stop. It just flashes on and off. I tried multiple times and each time, the SRS light blinks instead of the CEL.
This is a 95 Honda Civic EX
The connector I am jumping is blue with a green boot.
On the same wire loom is another connector with three contacts and is encased in some foam tape. I'm pretty certain I am jumping the right connector.
Anyone know how I can check my codes?
Does the CEL light stay on when you're jumping the connector? Usually it will go off, but with the connector jumped, it will stay lit. If you've got codes stored, then the MIL will start flashing to let you know what code it is. If there is a problem with the SRS, that light will flash too. My SRS light is on all the time, and when I jump that connector to check a CEL, the SRS light flashes too.
Its the same jumper to check CEL and set the timing. The connector you should be jumping is a little one that isn't connected to anything, but is generally tucked into a protector. Its up by the computer, and there are only two wires running into the connector.
Did your CEL come on at all to warrant you to want to check the codes? If the CEL came on (and you haven't reset your computer), then the CEL should blink at you when you jump that connector.
If the SRS light is on when you're driving, and you jump that connector, then the SRS light will flash at you just like the CEL would.
Yeah, yeah, you definitely want to make sure to remove that connector BEFORE actually going anywhere. You would run the car with that connector in there to set the base timing, but that's about it...
Well the two wire connector for flashing out the CEL is also how you read the SRS dtc's. If it flasshes long and short flashes than there is a code stored in the unit that may have been fixed at one time or another and the light is now out but the code is still there.
