clutch upgrade
Old 10-12-2005 | 04:39 PM
hobozcar's Avatar
hobozcar
Give Me Your Tots!
Default clutch upgrade
what is the recomended clutch for a daily driver a stage 1 or 2 or does it make a differance with those two?
Old 10-12-2005 | 07:32 PM
junior-ae's Avatar
junior-ae
I just put an ACT heavy duty clutch and pressure plate, along with an ACT streetlight flywheel in mine. Daily driver (96 EX). There's quite a bit more grab than the stock clutch, but I'm really happy with it. No other real mods to the car.
Old 10-12-2005 | 07:44 PM
Omniscient's Avatar
Omniscient
warm butter on toast
I got an exedy stage 1 for my daily. The pedal is a lot stiffer that's about it.
Old 10-13-2005 | 02:28 PM
1995Civic's Avatar
1995Civic
I hate ricers
I would not go above a Stg 1, unless you know you will be having some major mods done, to where you would need such a heavy clamp-load. If you know you will be getting major work done, within a year, I would either stick it out w/ the stock clutch, or use a stg 1 and then change later to a stg 2, cause you will not like/enjoy the stiffness of the pedal.
