Idle Problem
Old 09-28-2005 | 03:30 PM
Angelnshs2002's Avatar
Angelnshs2002
Default Idle Problem
Hi All,
I have a 93 del sol auto. For about 3 years i have had an idle problem. I have replaced so much stuff, but nothing fixes the problem. My car idles very low (between 300-600) and feels like it's going to stall at any minute. It jumps around and shakes my car really bad. It mostly does it when im stopped, but now its starting to get really bad and does it even when im going. When I am at a stop and give it gas, it doesn't go. I have NO power at all. Then, all of the sudden, my car finally relizes that im giving it gas and takes off. Before, I could put my car in neutral and it wouldn't be so bad, but now that doesn't help. Here is a list of everything ive replaced:
plugs and wires
fuel and air filters
value cover gaskets
distributer
PGM module (whatever that is)
muffler assembly
master cylinder
ignition coil
fast idle boost valve
IAC valve
O2 sensor
REMOVED throttle body and cleans ports
CLEANED groud cables
I think that i might need a new throttle body but dont want to replace it and my car still be messed up. so, if anyone has any other guesses please let me know. Thank you so much! o
