New to Honda, Idle problems already!!
Old 09-21-2005 | 10:48 PM
mikeunreal's Avatar
mikeunreal
Default New to Honda, Idle problems already!!
So i bought a 92 hatchback. It has alot of stuff done to it and i got a great deal on it. To fill you all in leme list some things I know about.
Full Tokico Suspension, Camber Kit and everything
15" Brozen Rota wheels
b16 motor
lsd b16 tranny
underdrive pulley
intake
exhaust
brand new paint, and headlights
new control arms
short shift kit
and some other stuff i dont know about
Anyway, so the only problem i have had with it so far is the idle. The guy told me he put a p28 in it and it solved this problem, which doesnt make any sense bc it uses a p30 since its a b16. It surges when it idles, and jumps from 1k to 2k. I went ahead and bought a virigin ecu for a b16 and am hoping this will solve my problem. Does this sound like the ecu or somethign else? Possibly a vaccum leak or the air intake control valve? What do you guys think?? Im new to honda. Before i had a gti and a mustang gt, so this is all new to me. Thanks!
-Mike
Old 09-21-2005 | 10:59 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
does it fluctuate? if so...does it go away when the car is at operating temp? if so...it is the Fast Idle Thermal Valve.
Old 09-22-2005 | 05:27 AM
dpkelly's Avatar
dpkelly
1999 Civic Driver
The FITV is for when the car is cold. The IACV (Idle Air control valve) controls idle when it is at operating temp. Located on the throttle body near the firewall, it's held on by 2 12mm bolts. Remove the IACV from the TB and clean out the screen to allow it to bypass the throttle valve with air more easily. You can clean with WD-40 or other penetrant. You can leave the coolant hoses connected during this whole time.
Old 09-22-2005 | 05:51 AM
delsol161's Avatar
delsol161
my TPS was dead... and it fluctuated until the engine warmed up. i replaced it, problem solved.
Old 09-22-2005 | 07:44 AM
mikeunreal's Avatar
mikeunreal
Default ya
Ya it does it when its warm or cold, doesnt even matter. argh!!!
Old 09-22-2005 | 09:00 AM
delsol161's Avatar
delsol161
so even after it's run for like 10-20 minutes, it still idles that way? try checking your plugs. the poots on the wires may have leaked, causeing a misfire... also happened in my car.
Old 09-22-2005 | 09:41 AM
mikeunreal's Avatar
mikeunreal
ya even after it runs forever it still does this, how do i know what to look for in the plugs? mabye my wires are bad? so many things it could be..
Old 09-22-2005 | 10:00 AM
delsol161's Avatar
delsol161
hehehe, i accidentally types poots anyway, my plug boots, right where they slide into the top of the head (through the valve cover), one had cracked. water got in when i cleaned the engine.... and bam.... nasty idle. check the spark, too, see if a cylinder is maybe not getting spark.
Old 09-22-2005 | 01:08 PM
mikeunreal's Avatar
mikeunreal
will try it
Old 09-22-2005 | 08:03 PM
asiandoood's Avatar
asiandoood
It could be a possibility of a few things.
Check the FITV and see if the plunger backed all the way out.
Check the IACV and clean it if it is dirty.
Check the TPS and see if it has the correct voltage.
Check your vaccuum lines and make sure there is no leak.
Is the fluctation fast or slow? Are you throwing any CELs in the process?
