Clutch tips/tricks
what's wrong w/ coasting in neutral and braking? wouldn't it save gas?
double clutching is real cool- if you are going, say 40 mph, in forth gear at 3,000 rpm's, just push in the clutch and rev the car to where your rpm's would be if you were driving in 2nd gear at 40 mph, then shift to seccond and floor it.
Originally posted by DSC
Dont grind it
i.e. grind it and revving to 6K=very very ver bad.
Dont grind it
I couldn't agree anymore....my tranny didn't like the 7200 rpm abuse...actually neither of my first 2 did. Hopefully the 3rd one i put in at 40K miles will last a bit longer In any case...downshifting and revving up to make the car not jerk is called rev matching not double clutching. And i'd rather put it in neutral and brake....the brakes are designed to wear down, the engine isn't. And would you rather pay 100 for some new rotors/pads of 1000 for a motor/tranny?
i totaly agree, its a good thing the d's trainies are relatively cheap, cause they are almost disposable if you race with them. does anyone know if the zc tranie is any stronger, or doesnt grind?
Make sure you shift all the way at the track. If not you could break a axel seal, along with the metal seal around it.
Had to buy a new tranny.
thats called rev matching, my friend.
I asked a friend of mine how to double clutch a bit ago and he couldnt explain it very well, but what i got from it is when you change gears (say 1st to 2nd) you do something like tap the clutch in 2 times or something, it didnt make sense to me, but it had to do with taping the clutch twice.
97 Honda Civic Dx Coupe.
