suspension techniques sway bar pic.
Old 07-29-2005 | 02:44 PM
03cbr600f4iguy's Avatar
03cbr600f4iguy
Default suspension techniques sway bar pic.
does anyone have a picture of a suspension techniques rear sway bar mounted on their 96-98 civic. i just got one off ebay, but it doesnt look like it fits. almost looks like it has to mount to where the shocks mount. not the normal hole in the lca's.
Old 07-29-2005 | 03:06 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Actually, that sounds about right. '96-'98 Civic's never had a rear sway bar so their LCA's don't have the hardpoint on the LCA to mount the sway bar too. I think the ST bars came with a bracket that attached to the lower shock bolt that you attach the endlink too. I never owned a set but I remember reading about them a while ago.
Old 07-29-2005 | 04:47 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
^wrong...
all 96+ civics have mounting locations in the lca (didnt I JUST say that?).
No 96-98 huh? Just because the states didnt have one, doesnt mean the rest of the world didnt....VTI, CTR are just 2. USDM didnt get "special" loser lca's w/o endlink holes.
The subframes also have mounting holes for D brackets...
Old 07-29-2005 | 05:03 PM
03cbr600f4iguy
anyone?? how do i put this freakin thing on?
Old 07-29-2005 | 05:42 PM
swissarmyca's Avatar
swissarmyca
In regards to your pic request....
this one also has the tie-rod installed.
File Type: jpg
Old 07-29-2005 | 06:16 PM
03cbr600f4iguy
im saying, installed on a car.
Old 07-29-2005 | 08:08 PM
PDiggityDogg
basically, that image is it installed on a car...without the body
See the similarities?
The rear plate/tie bar goes on first, with the lca bolts going through it, the D-brackets for the sway (and with it) go on next into the 2 holes on each side of the subframe (hope you got backing plates with it). Endlinks on the bars ends go on last, into the lca holes.
Let the car down and tq it all to spec
Done.
Old 07-29-2005 | 08:38 PM
03cbr600f4iguy
thanks for the help. i did get backing plates with it. will i need the beaks kit also? its 3/4", 19mm. it doesnt bolt to the normal hole on the lca's though. its like it has to mount somewhere near the shock mounting point.
Old 07-29-2005 | 08:43 PM
PDiggityDogg
take a pic of the endlinks
Old 07-29-2005 | 08:45 PM
03cbr600f4iguy
heres what it looks like. and some hardware. i dont know what the black thing is for. is metal. im assuning its for the front. the other two things, one set os for the front, one is for the rear. i think the bigger ones are for the rear, but i dont know for sure.
