manifold question..
Originally Posted by 92lx
if you could get your hands on a y8 head....and do a mini-me swap...that'd be even better
Nathan
Nathan
intake/exhaust manifolds and transmission would be the best things to gank from the y8. the mini-me swap is good for higher compression, tho.
Originally Posted by 18secFerio
yeah. even the throttle bodies are the same.
actually the y7 throttle body has the IACV built into it, while the Y8 doesn't. The y7 throttle cable plate is also angled slightly different, If you want to switch manifolds, you'll need the little brass peice that the throttle cable connects to off of the y8 TB
vertical tb's are aweful looking. i mean what was the purpose of honda bothering with that kind of set up? fuel econ? cost? anybody have an idea why honda ran that set up on civics?
