Misc. Engine Stuff
Old 06-18-2005 | 11:19 PM
Outxider's Avatar
Outxider
X-Motoring
:werd: get new clutch, flywheel, hondata im gasket, all new seals and gaskets if applicable. u dont need a header, msd, or the over priced aem intake if ur gonna go turbo. as far for cams and cam gears, get a set of itr cams and some gears, cuz u can utilize now and later. have fun bro.
Originally Posted by Shmoo
Agreed.
Also don't waste your money on an overpriced, worthless intake like the V2, a header of any kind, or the MSD ignition. You don't need any of those for a turbo setup except the ignition for high boost applications where the spark cannot jump the gap.
Old 06-19-2005 | 10:24 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Originally Posted by 4Banger69
ask anyone wont do anything without a good cam
People have tuned with cam gears on stock cams and have gained horsepower just by adjusting timing.
Old 06-19-2005 | 12:05 PM
Civic2Scooby's Avatar
Civic2Scooby
this thread is out of control....
if you are planning on turbo then...
A: dont waste your money on a AEM Cia v2...hell even if you were staying NA dont waste your money on that crap.
B: spend your money first on things that you need to do to the motor....ie...timing belt and water pump, new thermostat, cap rotor, wires, plugs, etc etc.
C: if you still have money do like suggested above and get things that will transfer over for your turbo application.
everyone below this line I want to punch in the face
__________________________________________________ ________________
Cams, Pulley set, exhaust, intake manifold. I would go for the V2 CAI for starters, thats me.
Originally Posted by flatliner
the msd with the external coil adapter and a m6d? you also need a adjustable pressure requlator to fatten for the spark output, and the cam gear is good, you need a vac gauge and pretty much test drive it a billion times. You are on the right track.
cam gear wont do crap without a good cam
Old 06-19-2005 | 01:48 PM
VTEC-Power's Avatar
VTEC-Power
true true
Old 06-19-2005 | 03:41 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Ok sop what I have gathered from all this is forget the AEM V2 intake, msd ignition, and the header......go with ITR cams and cam gears, hondata IM gasket, tune up (plugs, wires, rotor button, cap), and then save for the hondata and turbo stuff correct? Is there really a need for a new timing belt and water pump if the engine only has 30K on it? Correct if any of this is wrong please.
Old 06-19-2005 | 04:55 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
if you are sure about going turbo, skip all the crap. (V2, ignition, header, gears) wait until you know for sure what turbo setup you are going with, and go from there.
Old 06-19-2005 | 05:33 PM
VTEC-Power's Avatar
VTEC-Power
build internal for now atleast
Old 06-19-2005 | 06:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
That is exactly right. Investing in a thicker piping exhaust isn't a bad idea if you don't have one already.
Old 06-20-2005 | 01:04 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
What?
I advise you to read this : http://auto.howstuffworks.com/engine.htm
A more powerful spark will do nothing except maybe burn the fuel more efficiently, which is also the reasoning behind having more then one spark per revolution.
Old 06-20-2005 | 05:04 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Anyone know a couple good sites that I could order the itr cams and gears, and the hondata IM?
