b18c1'd civic Vtec Cutting out
Old 06-08-2005 | 07:00 PM
SSCivic's Avatar
SSCivic
Swolen Member
Default b18c1'd civic Vtec Cutting out
Hey everyone-
I dunno if anyone will know the answer to this problem without a diagnostic checkup run on my engine, but recently my vtec has been cutting out on me. When I get to about 6,000rpm, the engine seems to sputter and lose power. It's definately not an oil problem as I just changed my oil the other day and check it every time I drive. There have even been a few occasions where I'll start my car up and it'll either sputter down and shut off if I don't give it gas, or it'll die out of nowhere after I get on the road. That only happened 3-5 times at most, usually when I came out of gear after the car hadn't been runnig a while. On one occasion, it died on my while in third gear approaching a stoplight and wouldn't start up for about 5 minutes.
If the car isn't overheating, the coolant level is fine, the oil level is fine and everything else seems to be in order, is there something I am missing? Could I need a new ignition or what? Any hints, or should I just take it in to my local Speed Shop? Thanks!
Old 06-09-2005 | 08:49 AM
SSCivic's Avatar
SSCivic
Swolen Member
/bump no one knows?
Old 06-09-2005 | 09:15 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
are you throwing any CEL's?
Old 06-09-2005 | 12:23 PM
SSCivic's Avatar
SSCivic
Swolen Member
not at all. It's really messed up. I may go into my ECU today and see if everything is plugged in ok. the VTEC wire was run separate fromt he others... so I wonder if it is coming lose or something.
Old 06-09-2005 | 05:53 PM
flatliner's Avatar
flatliner
Fix It
what is that 14 second civic using for ignition ? stock coil?
Old 06-09-2005 | 06:06 PM
asiandoood's Avatar
asiandoood
interesting.
I would re-check the wiring, fuel pump, ignitor/coil. If the VTEC wire was disconnected or was going bad, I'd assume it would throw a code. Let us know how it goes.
Old 06-09-2005 | 06:07 PM
asiandoood's Avatar
asiandoood
most likely. hybrid setups in the EG/EK chassis running the 1.8 VTEC motor can easily run 14 - 13 second quarter miles stock.
Old 06-09-2005 | 06:39 PM
flatliner's Avatar
flatliner
Fix It
rereading that sounds like a poor something. Sputter and die, you first need to know integrity of spark and fuel when this happens, if you cannot test them shop time for you.
Old 06-10-2005 | 10:54 AM
LSturbo's Avatar
LSturbo
Hey everyone-
I dont think its your VTEC. I had that same problem in my car. I think you need new fuel lines to your engine. how many miles are on the car.
Old 06-10-2005 | 02:09 PM
SSCivic's Avatar
SSCivic
Swolen Member
well there's about 91,000 miles on the chassis, but 71,000 on the motor and all of it's components
