B16A Came Gears
Old 05-28-2005 | 08:04 PM
VTEC-Power's Avatar
VTEC-Power
Default B16A Came Gears
What are some good cam gears, that give a noticable amount of power?
Old 05-28-2005 | 08:20 PM
FATHONDA's Avatar
FATHONDA
im using aem at negitive 2 with a 30 cut. its ok... Don't like the chrome bolts that arent heat treated, that is bad. otherwise buy them with confedence of your valves.
Old 05-28-2005 | 08:24 PM
VTEC-Power's Avatar
VTEC-Power
i do have them at -2 also but I am looking for something better
Old 05-28-2005 | 08:37 PM
FATHONDA's Avatar
FATHONDA
have your cam cut. it should cost you about 400$ if you pull your cam out.
Old 05-28-2005 | 08:42 PM
VTEC-Power's Avatar
VTEC-Power
Na I didnt, I have just been looking at different gears, thinking AEM just sucks
Old 05-28-2005 | 08:44 PM
FATHONDA's Avatar
FATHONDA
they all do the same.
Old 05-28-2005 | 08:46 PM
VTEC-Power's Avatar
VTEC-Power
Ok thx, I thought though there is a difference between CTR and ITR Cam Gears
Old 05-28-2005 | 09:27 PM
Snoopy's Avatar
Snoopy
been there done that
this thread is like the blind leading the blind :screwy:
camGEARS will not give you any power. camSHAFTS will. when properly tuned with supporting mods.
Old 05-28-2005 | 09:54 PM
VTEC-Power's Avatar
VTEC-Power
lol
Old 05-28-2005 | 10:50 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Exactly what I was thinking...
If you have cam gears, adding different ones won't do you any good. -2/+2 deg is the same regardless of which gears you are using. The only reason I can see changing gears is that the ones currently used are slipping or you just want to change brands/colors. Very much blind leading the blind... :doh:
