Electric Supercharger
Old 05-30-2005 | 06:58 AM
givemeyourstd's Avatar
givemeyourstd
cottage cheese!
The guys at www.homemadeturbo.com did a test on these "electric" superchargers and it looks like they actually lost HP because of the restricted airflow.
Don't be a jackass.
Old 05-30-2005 | 07:10 AM
Randomher0's Avatar
Randomher0
VSC EM1 13.1@106 RIP
Originally Posted by mopar67624
I just bought a Venom 400 for my civic ... I have a 99 Civic DX with some extras it should handle it fine.
this is what should be bothering everyone. why on god's green earth would you put huge injectors on anything boosting less than 8psi?
Old 05-30-2005 | 07:21 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
That's what I'm saying. Adding fuel to an N/A motor that is very mild is useless...
Old 05-30-2005 | 10:25 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Originally Posted by FATHONDA
h22. it boosts low end before cfm measures fight it, the reason the ele fans die is because of high rpms under a load forcing them to spin faster causing a negitive feedback to the coiling of the motor. you would almost have to have a bypass valve for pressurizing. its not worth it in my book.
Do you even speak English?
I can't figure out for the life of me what that means.
Old 05-30-2005 | 11:43 AM
eonsx311's Avatar
eonsx311
today is not my birthday.
he means that when the engine is sucking in air faster than the stupid electric supercharger can push it. it causes the fan blades on the thing to spin faster than they were designed to, causing them to snap off at high pressure. you would need to bypass once you get past low rpm's so that wouldnt happen.
Old 05-30-2005 | 01:18 PM
FATHONDA's Avatar
FATHONDA
thanks, do zo yo rou shiku!
Old 05-31-2005 | 05:58 AM
eonsx311's Avatar
eonsx311
no prob mang
Old 05-31-2005 | 11:10 AM
wilsel's Avatar
wilsel
First of all the Venom 400 is an electronic module that fools the ECU into dumping more fuel. (It's not larger injectors).
2: The tornado is absolute crap. I wasted $75 on one 10 yrs ago when I was 16 and dumb. Didn't do jack. I checked my gas mileage, no improvement. I wanted to kill the little old lady in thier infomercial who said her 3 cyl. Geo had power after installing it.
3. Don't buy an electronic supercharger it's garbage.
Old 05-31-2005 | 02:49 PM
FATHONDA's Avatar
FATHONDA
wilsel. on my d15b1. the nado does well, because i took the top plate out of the TB and the air beam inside the top casing, there is no mixture control, the nado definately did me well in my scenario.
