Latest set of mods
#42
#43
Jealous! I planned on doing some fun stuff to my B16A this year since it's being retired as STS car
Autocross Help Page
Autocross Help Page
#44
#46
obviously they'll make more power, they are have a more aggressive setup.
but the itr cams have more overlap than the stock cams you had.
which'll probably make less power up top.
as far as i've researched, less over the better on a turbo setup.
i could be wrong.
edit: you want more power? coming out of a turn you'll can't put down most of that power already, why go for more?
i could be wrong.
#47
i could be wrong.
i could be wrong.
i was thinking the same with the ITR cams....but i wasnt sure h:
#49
It's a myth and an internet stigma. As per some research I've been doing and been consulted about: the pressure build up that you get in your exhaust manifold can be so great, especially in a log-style, that when the exhaust valves open there is a conflict based on the pressures. It can get to the point where the exhaust from inside the manifold can actually seep back into the combustion chamber causing you to reburn exhaust gasses. When you use a cam like the ITR cams that have a good deal of overlap, you use your boost pressure to help keep that exhuast pressure out of the combustion chamber, but it needs to be tuned correctly. The ITR cams will also be tuned with the adjustable cam gears so if need be I can just tune out the overlap if it comes to that.
I've thought this out.
Oh, and Bumnah, because it's there. h:
#50
i could be wrong.
i could be wrong.
This is a dyno with before and after cam gear adjustments on a turbo honda. The adjustment actually added in overlap.
Droperly dialed in overlap is excellent for boosted hondas.
