engine swap D13b2 for a D16Y8
alrigh you are gonna need the rear transmission bracket from a 92-95 tranny if the y8 already came with the tranny, you are gonna need the wiring harness from an ex, or si of your obd preferably a p28 ecu from an obd1 ex or si manual and it should work fine although the y8 has a plug for a knock sensor you will not have to use it since obd 1 engines didnt require use of one, also the y8 has a wire in front of the timing belt for the crank angle sensor i believe but you can just let it be and you'll be fine good luck
Originally Posted by IMPORTGIRL76
u have the y8 already? ihave one if u are interested in buying it
ill buy the loom for this engine if its avalible think i can use the y8 is this right there both d-series sohc vtec
Originally Posted by mugen-civic
cant seem to find much info on this swap help
It should be pretty similar to swapping a Y8 into a US market CX.
