sway bar question..
it would be a safe bet it will hold up better then the beaks or the bsq kits, where its only reinforced only at the boltin holes, rather the aspec plate is a complete one piece to evenly distributed the load. its a winner.
Originally Posted by oc_civic
so again... with think with the a spec plate i can run a 19 20 mm bar all day with no problems???
Originally Posted by Outxider
my friend has a 00 dx with es poly bushings kit, tokico R coilovers, and srr lcas. he ran a usdm 22m itr sway bar with the beaks reinforcement kit, guess what happen? the right side of the subframe ripped out like its paper. he cut both sides off, cuz the left side show sides of spider cracks, and weld in new pieces reinforce with small metal plates as well but he decided he wont run the bar til he gets the aspec racing subframe reinforcement plate that covers the entire subframe to ensure equal distribution of the stress from the bar.
what about putting a 99-00 SI sway bar on a 97 EX... will my subframe hold or will it rip apart?? or can I put a 94 GSR sway bar without any mods?? and will it hold or rip apart?? which one of these two is better??
in ur case it wil be fine, those r dinky sway bars and will not harm ur subframe. the si bar is 13mm and the gsr is 14mm.
i was going to do this soon, but because i have to buy the plate also, it will be put on the back burner... im going with the ST or progress bar and the a spec plate... i guess i am sure i wont have any issues with those....
I have the Comptech tie/sway bar. No problems after a year or autocrossing. Definitely a better improvement over my stock Si sway bar.
Autocross Help Page
Autocross Help Page
Originally Posted by DamnUndrSteer
im his friend... the sadness... please get the aspec reinforcement...
wow, thats just about the worst tearout I've seen :eek3: Maybe I should start thinking about those plate thingies... I haven't had any problems with my beaks so far, but... :ugh:
