spark plugs do that??
Originally Posted by 89civicSiR
thanks for the advice, how much do you think for port and gasket??? or even just gasket
The gasket will be under $10, a can of cheap carb cleaner will run about $2.
i wasnt gonna dont worry but thanks for lookin out. my car stopped doin this whole deal with the high rev now but im gonna clean out the throttle body anyway and now its boggin down when i start it. but only for the first minute or so until it warms up when i first start the car if i step on in i hear the intake and it almost quites on me but if i just tap the pedal i can slowly build up rpms.....think it might be adjusting to warm weather??? cuz its been hot out for the past day and thats when the boggin down thing started....probably wouldnt hurt to clean out injecters too right?
actually yes, seafoam will help clean the injectors and the intake and can be used on the throttle body inside and out to clean out the carbon rather than the carb cleaner. It will also lube the throttle cable and stop it from sticking if you use the seafoam spray.
Dumping it in the gas tank or cleaning the PCV valve with it won't go jack to unstick a throttlebody. Maybe it he sprayed it in the intake tube at the PCV feed it might help, but it won't do nearly as well as a full removal and hand cleaning of the TB.
well today i actually have the time to take shit apart so ill let you know what comes of it......so if i take off the tb and spray it with seafoam will it help more than carb cleaner???.....also anything to watch out for when doing this, im goin to walmart to get cleaner and prob seafoam so now would be the time to let me know ....thanks for all the help
ok ive cleaned out the tb and while i was at it i cleaned out the pcv and now it seems like i have more power but it idles between 1000 and 2000 and when ever i push in the clutch it goes straight to 2k and if im at a long light it will eventually come down around 1500. any ideas would be greatly appreciated
