Vacume Issues
Originally Posted by Running925
ok.. so basicly u guys are sayin, plug it all up & adjust the idle screw on the throttle body to compensate for the engine dieing. (dieing is due to lack of air getting into the engine to remain running). ?? just wanna be sure on this?
hey guys. just want to check somethin out here. I think i've got all my vacume leakage taken care of. I hooked up my boost gauge to see what kinda vacume pressure i had. I noticed that i had about 15 or so lbs. of negitive pressure, & when i opened the throttle up a little bit it would jump up (not all the way to zero) but then while it was open something would compensate for it & bring it back to my origional negitive 15 lbs. of pressure.
I wasn't sure if this was right nor not so i hooked my boost gauge up to my d15 beater mobile & did the same test & got the same resultz.
just figured i'd share that with u guys, i've been questioning my self a lot lately for some reason.. just bein paranoid i guess!
so the idle problem is fixed?
the vacuum thing sounds about right. when you push on the throttle the vacuum from the intake is filled by incomming air, the RPMs climb and create a vacuum in the intake again. A never ending cycle....
I've found a little paranoia is good, keeps you second guessing and not messing anything up.
