Vtec Engagement problem
It's my first day.
Originally posted by MNY2BRN
just bein a cac man, sorry, long day of dealing with idiots at work. And when you clean out the solenoid, what do you clean it with?
the leaning into turns thing though makes me think electrical issue or low fluid level issue...i would check to make sure the lines running to it weren't grounding out somewhere.
and call me if my **** comes tomorrow, and ill bring thebalance, im off for most of the day.
I had the exact same problem. His oil is low. Sounded dumb to me to, but fill it. You'll see Don't start playin with the solenoid or anything unless you have to. That part is like $250. For that little piece!!!! Basically the V-Tec will stop kickin in before your oil light comes on.....in other words you don't need an oil light
I hate you too
Originally posted by crucial Si
oh im sorry mr honda mech know it all.
Honorary Moderator Alumni
If it cuts out on you on turns then your oil is low. Keep the oil level in the middle or at the high end of the full level on your dip stick (did that make sense?)
My power steering cuts out on me with a 3+ cone slalom because the power steering pump cannot keep up with the left and rights.
Autocross Help Page
Autocross Help Page
Do you suggest an oil other then Mobil 1?
Autocross Help Page
Autocross Help Page
