misfire detected?????
Old 01-25-2005 | 04:41 PM
xblackxsheepx's Avatar
xblackxsheepx
Default misfire detected?????
97 honda civic hx
check engine light came on again today
P0301 misfire detected cylinder 1
P0302 " " cyl. 2
P0303 " " cyl. 3
P0304 " " cyl. 4
P1300 dont know
P1399 manufacture controlled igntion system or misfire (pending code)
The spark plugs are gapped to specifications
The distributor and cap are in excellent shape
The timing is within specifications which is at 13 degrees
Still can't figure it out??? Any ideas???
Old 01-26-2005 | 04:27 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
could be the ignitor in the dizzy.
Old 01-26-2005 | 10:18 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
P1300 Random Misfire
It could also be water in the fuel. I'd clear the codes, fill up with fuel and see if they come back.
if they do, the ignitor would be the prime suspect.
Old 01-26-2005 | 07:20 PM
xblackxsheepx
thats the next thing im gonna try is to fill up with fuel then put some heat in the tank
Old 02-04-2005 | 06:20 PM
xblackxsheepx
dang the exact same codes came on today im just running out of ideas of what to check
Old 02-04-2005 | 11:13 PM
MPerson's Avatar
MPerson
Gotta be the ignition system with those codes, im with NeverBX on the ignitor.
Old 02-05-2005 | 06:14 PM
Hondaman's Avatar
Hondaman
Black Pearl
Honda had a recall on this problem. Talk to your dealer to see if you are eligable.
Old 02-10-2005 | 07:06 PM
xblackxsheepx
car gave me codes today
PO303
PO304
P1300
tried doing the test on the oxygen sensor and the scan tool would not let me, but a ran the datastreem and it says
O1S1 .50 and the rich light was on
B1S1 14 dont know what # means
O1S2 .87 and the rich light was on
B1S2 14 dont know what # means
dont really know what any of the other numbers mean but i know that the oxygen sensors say its running rich. Dont really know waht to do or whats wrong maybe the timing is off a degree or so i think its at 13 degrees, any ideas????
Old 02-10-2005 | 07:24 PM
aero3685's Avatar
aero3685
my moms keeps having cylinder misfire and junk. . Ive gotten sick of checking the codes, and messing with it.
What is this recall about?
hers is a 97 dx i think
Old 08-23-2005 | 06:32 PM
ToxicByte's Avatar
ToxicByte
What is the recall about?? What cars are eligible? I've got a '97 Civic.
