Cheap brake upgrades
Old 01-24-2005 | 11:57 PM
thomas's Avatar
thomas
pew pew pew
Default Cheap brake upgrades
i was wondering if there where any other oem honda clalipers that would fit on my civic, i.e. accord calipers..... the nissans were all swapable...
Old 01-25-2005 | 01:45 AM
Honda3002's Avatar
Honda3002
I do beleave that you can swap out the old stock civic calipers with a set from Acura Integera plus you can go with the 5x114 mm lugs or go with the 4x100 mm lugs. here is web site i found for such swaps.
http://www.passwordjdm.com/prodtype....ageHistory=cat
Old 01-25-2005 | 04:54 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
The largest you can go on the ex is the late legend/nsx brakes.
Then ITR/Accord Wagon/Prelude vtec.
Both sets require you to use a 5x114mm rotor redrilled to 4x100 AND 2 sets of spacers along w/ extended lugs, to work on the current hub. You could also change to 5lug and skip that step, but it will cost a lot more.
(If you dont want to use spacers, you can shave the caliper down...but I like the idea of wider track)
The smallest upgrade would be from an integra (any minus itr) or abs civic (both are the same size piston). They bolt directly onto the ex knuckle and are bigger in size than the ex/si caliper piston.
Either way, I highly recommend upgrading to a 1" mc and booster from an itr or gsr integra (I have a how-to written up somewhere on here)
Old 01-25-2005 | 08:12 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Well what's wrong with your stock brakes? If you can lock up your tires with your brakes now they should be fine. Which means your tires suck.
I recommend Brembo Blanks, AEM or Hawk HPS pads, Goodrich stainless steel lines and Valvoline Synpower or Motul brake fluids.
Autocross Help Page
Old 01-25-2005 | 08:17 AM
Kestrel's Avatar
Kestrel
Push to shock!
Stoptech makes a kit which includes rotors (I forget the brand), Axxis pads, stainless lines and nicer fluid for about $400 I think. Also, I think you would benefit just from converting your rear drums to disc.
Old 01-25-2005 | 08:53 AM
thomas's Avatar
thomas
pew pew pew
what size are stock ex brakes....
Old 01-25-2005 | 09:50 AM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
I'm with CSR. Brakes don't stop a car, your tires do. (Well actually it's the whole chain of braking system.) But to actually improve braking (or anything for that matter) you'll need to address the weakest link. So, when you jam your brakes and you can't lock up the tires (or activate ABS); then it suggests that your tires have more grip in them and then you'll need to do something for you brakes.
When I put new tires (Yoko ES100) on my car, the stock brakes didn't always lock them (depending on conditions). It was time to replace rotors, so I went with Brembo blanks and PBR Metal Masters... a mild "upgrade" (keeping stock caliper). Now my brakes activate ABS way to quickly.
Point is: maybe you just need higher performance pads.... and that's cheap.
Old 01-25-2005 | 09:51 AM
ED9man's Avatar
ED9man
driver
It's nice when you just barely touch them and it hauls the car down fast.
But that is true, unless you are a hardcore racer with brake fade issues I don't see why you would upgrade aside from rear disc.
Old 01-25-2005 | 03:19 PM
chimchim's Avatar
chimchim
Sometimes this can actually reduce your braking performance (aka make braking distance worse). I'm thinking that even a minor upgrade like front pads is useless unless you've also done a rear drum to disk swap.
Old 01-25-2005 | 04:33 PM
thomas's Avatar
thomas
pew pew pew
so drum to disk rear is what you would recomend.....
