H22 swap.
Old 12-07-2004 | 11:01 PM
92lx
Guest
Posts: n/a
the LS is actually only 142 stock hp, but anyhow...
The LS N/A stock is a fun little motor to drive, but it compares little to an H22, B18C1 or B16 really, when it comes to overall power.
My LS, as well as most LS-swapped hatches that I know, are running anywhere from (claimed) high 14s..... or in my case, 15.5@88.6 mph (and I have calculated that on paper, 15.3 is about the best I can get on street tires).
The LS puts down about 120whp stock, mine put down 126.36whp today with a header and intake (and a 2" exhaust that's essentially stock though w/ stock-style muffler).
The LS motor can be picked up for basically nothing however, and is a very simple swap. It can be boosted easily, it can take nitrous easily, and - yes, it can even be built into a fairly powerful all-motor engine as well, with several people running over 170whp without going to an LS/VTEC setup.
LS/VTEC is another option, but you'll need to research that on your own
Old 12-08-2004 | 01:51 PM
Nelson's Avatar
Nelson
Administrator
Originally Posted by shady@teamproto
I used to own a 94 Accord, I put the H22 in it and it was a big difference from the SOHC to the DOHC. but in a civic the engine is way more heavier than any B-series engine and will be an extremly snug fit. plus you would have to go with an obd I H22 which really isnt as good as the OBD II H22 power rate ratio loss, HP gain. the engine also was set in a manner that was a longer more heavier vehicle, which the civic unfortunally is not. all in all H22 great engine, putting it anything else than a prelude or Accord well let me put it this way if you only plan on going staright, great but as a daily driver and going fast in every kind of direction not a great idea.
Totally agree.
LS is also a great motor for the Civic. Plus, have the option of slapping a VTEC head on it later on.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 12-12-2004 | 09:03 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
I want the 2.2, for the HP gains compared to the 1.8. I know if you put a header and Intake on a 2.2 you will gain more HP than if you put the same setup on a 1.8... So in other words, I would get more bang for the buck. I also dont plan on doing much to the motor, besides a few bolt ons.
Old 02-25-2005 | 11:12 AM
Wheezer's Avatar
Wheezer
What about the axles with a H22A in the civic. Will the accord axles fit the trans and wheel splines of the stock civic front end???
Old 02-25-2005 | 01:17 PM
Civic2Scooby's Avatar
Civic2Scooby
its a combination of accord intermediate shaft and 92-93 integra axles. I beleive
