Just got a 92 HB
Old 12-01-2004 | 09:29 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
Originally Posted by slowciv
.Given that the drivers were horrible and i have a little more experience.LOL
bad type-r drivers and most likely gsr ones too, isnt enough to say that an LS swapped eg is faster than an r, or gsr.
given two good drivers, an LS eg is comparable to a b16 eg
Old 12-01-2004 | 02:55 PM
Zzhatch's Avatar
Zzhatch
i had an LS in a cx hatch and i would pull on GSR's. Ofcourse stock ones.
He should still leave the B20 block in and do the VTEC conversion.
Old 12-01-2004 | 04:31 PM
Civic2Scooby's Avatar
Civic2Scooby
**** the VTEC conversion...sleeve it, boost it, done. h:
Old 12-01-2004 | 05:28 PM
honura's Avatar
honura
Seni
Thanks! Well here is the deal. There is no problems with swapping the motor. I currently got a shop and don't mind swaping in the gsr if need be. I just don't have heat in the shop and don't think I will for a while so I am trying to get what is needed done asap this way I don't have to deal with it later on in the mid winter when it's -0 or at least feels that way. Ummm I drove both the B20 and the GSR in a 97 cx hatch and I think the GSR had a hell of a lot more pull but then again I could be fooled by the VTEC. What do you think? The B20 has a stock clutch and all. The gsr has a Act clutch, flywheel, pressure plate the whole nine. they both perrrrrrrrrr like baby's. b20 is a 97. GSR is a 96 ehhh I know most of this does'nt matter but I figure let me give the most imput on it this way everyone gets a good idea of the problem.
Old 12-01-2004 | 06:34 PM
jeterkm02's Avatar
jeterkm02
think about moneywise though. the money you spend on a gsr, you could spend on building that b20 as mentioned above, sleeve and boost. then you'll be running circles around the gsr.
Old 12-01-2004 | 08:03 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
But if you had the cash later on to do more to the GSR....
Just as everyone has told me, it all depends on what you want to do in the future, and what you want right now. If you want a simple power swap, GSR, if you want another money pit project, go have fun with the B20....
Old 12-01-2004 | 08:10 PM
jeterkm02's Avatar
jeterkm02
id still do b20boosted
Old 12-02-2004 | 06:38 PM
Zzhatch's Avatar
Zzhatch
Well you should'nt swap the motor out, just take the Gsr head off and put it on the B20 block. Ofcourse you need to a little more than just that, but that would be the first step i would take to doing the b20 vtec conversion. Or, if you have the money, sleeve it, put forged internals, do some headwork, and you'll easily be close to if not above the 200 hp range all motor. Then you also would have the option to go turbo and on a sleeved block you can easily boost 15 psi all day.
Old 12-02-2004 | 07:27 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
I think that would be best....
Old 12-02-2004 | 10:31 PM
Civic2Scooby
**** a CRVTEC...its not that sweet, and the money it would take to make it sweet, would be better spent on boost.
