Throttle problems, please help
Old 08-20-2002 | 04:30 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Fuel Filter instructions...
-Open the gas cap to relieve fuel pressure
-Take 2 pairs of locking pliars, lock down on each of the hoses about 1'' or 2'' behind the metal tube where the rubber one attaches to.
-Unbolt the banjo bolt which is the first bolt on the left. Make sure not to drop any of the small pieces.
-Unbolt the service bolt which is the other one, and it has the funny shapped top part.
-Unbolt the band that holds the fuel filter from the bracket.
-Pull out filter and replace and install.
-Reattach the connections using brand new washers. Tighten the banjo bolt to 16 ft-lbs and the service bolt to 11 ft-lbs.
-Put the gas cap back on, turn the key to ACCII so that the fuel pump turns on, go check the fuel filter and make sure no gas is leaking out. If you don't see anything you are ok and done. If you see gas come out go back and make sure you properly tightened those connections.
Old 08-20-2002 | 05:08 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
make sure you put on new brass washers, the old gay ones will leak like a silve if you leave em alone.
i pull that pcv valve every oil change usually. it harvests old gas to reburn, and if it isnt it just dumps it i think, and it starves for fuel. it thereby effects performance and mileage.
simple things like this are detailed in your chitlons, but like everyone, you should really have a helms. (me too )
Old 08-20-2002 | 07:40 PM
MNY2BRN's Avatar
MNY2BRN
I hate you too
the new fuel filter helped a little, but it still acts up. i'm gonna do the pcv and tps sensor check tommorow.
Old 08-22-2002 | 12:01 AM
matvtec's Avatar
matvtec
If the problem still persists, try to check your fuel pressure. If the pressure is low, then your fuel pump might need replacement.
Old 08-22-2002 | 02:29 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Easiest thing to check are the spark plugs. I had acceleration problems and turned out to be those.
Autocross Help Page
mrintegra
08-14-2005 05:21 PM
estoner102
92+ Civic/EL & Del Sol
04-03-2004 06:39 PM
1fastercrx
CRX & Pre 92 Civic
07-28-2003 07:54 AM
jermothedrunk
2
07-24-2002 10:58 AM
Quick Reply: Throttle problems, please help
