Fuel Pump Cutoff Switch
Old 11-01-2004 | 06:53 AM
XCM828's Avatar
XCM828
stay off of wet roads
I'm guessing that since the fuel pump's fuse is 15A, then I'm gona need a 15A relay right?
Old 11-03-2004 | 10:42 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
Originally Posted by alphaxxn
I heard of someone running a cutoff switch on starter,fuel pump,and the clutch, pretty cool..alot of work id imagine though.
That’s what I did. Clutch cut kills the starter. Fuel pump prevents the car from being push started. And I added another line kill just to be sure my car doesn't go anywhere. (the person that buys my car is going to hate me)
yes that's right. But I'd go with the 30amp Radio Crap relay. their 15 amp relays are highly overrated. I've destroyed more than one with under 10amps running though it.
IMO it’s easier to just stop the OEM fuel pump relay from turning on. Interrupt the green/yellow wire running to the main relay, just left and behind the fuse box under the dash. It has max of 0.5 amps running through it.
