Guess my alignment problem
Old 10-24-2004 | 06:32 PM
aero3685's Avatar
aero3685
Originally Posted by CivicSiRacer
Do not give out false information if you are pulling it out of your butt. You don't need to get an alignment when you change wheels/tires. Hell I would be forking out $1000 a month if I did that (since I change tires every weekend sometimes 4 times in one weekend).
You do need an alignment everytime you change something on your suspension. Lower or raise the car, adjusting camber, etc....
The feathering is usually from too much toe (either out or in). In my opinion if you ask for 0 toe front and back you get better wear and better turn-in without sacrificing skitterish steering. Most tire wear comes from toe not camber.
Thanks.. i was pretty sure i was correct.
Old 10-24-2004 | 07:26 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Also, I see you've got Kumho's. You can't really rotate a directional tire like that and that will also cause wear since you can't really balance them out by swapping sides and locations. Swtiching them front to back once a while might help slightly.
Old 10-24-2004 | 07:59 PM
MahoneyL80's Avatar
MahoneyL80
I want 2 B cool like u!
Old 10-25-2004 | 05:04 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Originally Posted by MahoneyL80
wasnt pulling anything out of my butt.. but considering ive been driving cars for about 9 yrs now and working on them for 12 this applies to any car not just import customs. if you change out the wheel and the tire something is going to be off...and im not talking about going to the track and throwing on your steelies with drag radials every other weekend...im talking about having a certain size rim and tire on for so many yrs/months ...with that much wear then changing to another tire/rim combo with different wear on them..the alignment is going to be off because incase no one has notice the alignment on a car isnt a solid correction...after time your alignment becomes off by how ever much whether it be the camber or toe its going to change over time...especially with people in the north with the roads in the condition they are (potholes/driving in winter/uneven roads) thats why most normal people get alignments once a year or every time thy make a major change to the wheel/tire combo...i had a perfect alignment when i had my stock 14's on then as soon as i changed to the 17" wheels my alignment was somehow off....mainly because i went from old worn tires to brand spankin new kumho's so they had to adjust the alignment by only a degree if that....so i know what im talking about....tyvm
Well whoopie you have been driving for so long. I know people who are 55 years old who still don't know how to drive. So what's your point? I've been driving since you were 11 or 12 years old, so...??
Even if the tires is really worn down it's still going to give an accurate alignment reading on the rack. Tire wear does not affect your alignment reading. Now a bad alignment will wear your tires bad.
Autocross Help Page
Old 10-29-2004 | 09:43 PM
Hondaman's Avatar
Hondaman
Black Pearl
Well, I got an alignment done today.
Here's the specs.
The front was fine so I'll just leave that out.
Rear
Left
Camber
Actual -1.8 deg
Before -1.8deg
Specified Range -2.0deg to 0.0deg
Toe
Actual 0.09"
Before 0.07"
Specified Range 0.02" to 0.08"
Right
Camber
Actual -1.7 deg
Before -1.7 deg
Toe
Actual 0.08"
Before 0.10"
Total Toe
Actual 0.17"
Before 0.17"
Specified Range 0.04" to 0.16"
Thrust Angle
Actual 0.01 deg
Before -0.02 deg
They said since it was so close to being within spec, they just left it. I was kinda :eh: but it saved me $25 as they just checked the alignment and didn't adjust. Total bill: $26.70
