CEL came on today...
And I dont really know why, my oil is fine, I dont really know how to check the codes. What else could it be? I had to convert from obd0 to obd1.. the o2 sensors were messing it up a while back, but they were fixed, could they have effed up somehow?
thankss
thankss
thankss
thankss
Try doin that (it's pretty easy) and tell us what codes ur gettin. Then itll be really easy to find the problem (hopefully).
they are the same for the 99-00 Civic as the ones listed in the chart.
only difference is 48 is the Primary O2 sensor failure not LAF failure (which is basically the same thing anyway)
Okay I did the little test 3 times and I got 61 everytime.
61 = Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
What do I need to do with this?
I have a 99 Civic Si
which ECU are you running? that's all that matters.
