How to remove silencer from muffler please help
the easiest way to do it is just let the exhaust get really hot like go on a drive for like 20 minutes and then stop the car and pull the silencer out with a pliers or somethin. making the exhaust heat up makes it expand a little bit so its easier to pull out.
I've never had a problem removing my silencer. Probably because it's loose to begin with and I have to screw it in really tight for it not to move
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
fawk all that unscrew it start car rev it alittle it should pop out if not it shoul loosen it enough that you can use a coat hanger once again to pull it out if not spray WD-40 wait alittle while rev again and try it with a coat hanger
